Creaver 55 Report post Posted June 19, 2008 Hey guys, I intend on replacing the fluid etc on my auto this weekend. From what I can tell, there is no sort of filter to replace and I cannot use dexron (whatever that is according to the manual) and a special oil is required. Just wondering what sort of oil I am supposed to use, and where I can get it from...Glenn maybe? Cheers. Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted June 19, 2008 Yep, go see Glenn, he's not that far from you, very helpful. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted June 19, 2008 There is a filter inside the pan and you'll need a pan gasket too. Your car could take either G3 full synthetic or longlife oil. There will be a sticker on the bottom of the pan which will tell you what type. It's best you don't do this yourself...there is a correct proceedure. If in doubt... give me a call. You also need to check the change shaft seal and wiring harness seals for leaks. Clear adaptions as well after the trans service. Cheers Glenn Quote Share this post Link to post Share on other sites
