ice-creamzE39 0 Report post Posted June 26, 2008 in need of a new or good working condition 1998 523i e39 AIR FLOW METER. Siemens 5WK9 600 1 703 275 >PBT - GF30< Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted June 26, 2008 in need of a new or good working condition 1998 523i e39 AIR FLOW METER. Siemens 5WK9 600 1 703 275 >PBT - GF30< Second hand will likely give you trouble...unfortunately you will have to go new from the stealers I can get bosch at better prices ...but not Siemens Quote Share this post Link to post Share on other sites
ice-creamzE39 0 Report post Posted June 26, 2008 Second hand will likely give you trouble...unfortunately you will have to go new from the stealers I can get bosch at better prices ...but not Siemens Thanks, Whats the differance between brands? If I buy a bosch one at a better price, i will have no troubles? cheers, rob Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted June 26, 2008 Thanks, Whats the differance between brands? If I buy a bosch one at a better price, i will have no troubles? cheers, rob If its Bosch you must replace with Bosch, Siemens replace with Siemens...no mix & match unfortunately Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted June 26, 2008 some VW parts are the same....and cheaper too Quote Share this post Link to post Share on other sites
elliot7 0 Report post Posted July 16, 2008 I have a new AFM, matches up to BOSCH 0 280 217 110, and OE 13621736224 Listed to suit E36 318is, E36 318ti, E38 750, E31 850, Z3 1.9 $150 Located in Auckland. Quote Share this post Link to post Share on other sites
SD European 0 Report post Posted August 10, 2008 in need of a new or good working condition 1998 523i e39 AIR FLOW METER. Siemens 5WK9 600 1 703 275 >PBT - GF30< Hi there did you end up finding a airflow meter? Quote Share this post Link to post Share on other sites
