ice-creamzE39
1998 523i e39 AIR FLOW METER
in need of a new or good working condition 1998 523i e39 AIR FLOW METER.
Siemens 5WK9 600 1 703 275 >PBT - GF30<
Second hand will likely give you trouble...unfortunately you will have to go new from the stealers
I can get bosch at better prices ...but not Siemens
Thanks, Whats the differance between brands? If I buy a bosch one at a better price, i will have no troubles?
cheers, rob
cheers, rob
If its Bosch you must replace with Bosch, Siemens replace with Siemens...no mix & match unfortunately
I have a new AFM, matches up to BOSCH 0 280 217 110, and OE 13621736224
Listed to suit E36 318is, E36 318ti, E38 750, E31 850, Z3 1.9
$150
Located in Auckland.
Hi there
did you end up finding a airflow meter?
