balthazar
e30 dash light and rev counter problems
Righto, so bought another 318i and shes having a few electrical problems.
List is:
Rev counter not working
Park light warning light always on (flicks on and off when engaging and disengaging but stays on)
Fog lights not working
Oil Service light stays on
With the oil service light I tried using a LED test lamp like I was told but to no avail.
Anyn ideas?
Rev counter not working Try replacing SI board batteries, Info Here
Park light warning light always on (flicks on and off when engaging and disengaging but stays on) [edit] broken sensor on handbrake lever. I took out the bulb in the instr. cluster on mine.
Fog lights not working Check fuses/bulbs or clean the contacts in the fog light switch next to headlight switch.
Oil Service light stays on Reset SI board lights, Info Here. This may not work until you have replaced the SI board batteries as they may be flat (making you your tacho not work).
Edited by Quailboy
