plumbernz
help
put key in and it just turns around and around
now it will not turn at all
Edited by cutit
oooh need to replace the battery in the key for the transponder i believe.
Its your factory immobilizer
thanks pjay looks like a new barrel needed
No it can be fixed. We get our locksmith to do them all the time. Its a broken pin in the end of the barrel
Where abouts are you ?..in Auckland ??
hi botany moter works i am in howick
If you get it towed to me this morning I can get it fixed for you today
$100 + GST
Pakuranga Towing can get it to me Ph. 5761300
Give me a call Ph. 2722546
Glenn
Job done...all fixed... wasnt an easy one either. Our locksmith normally charges $240 + GST to do this if you call him. Thats why I dont give his number out. Cheaper to get it done through me.
Mine does it once a month if that. Still oughta get it fixed?
sh*t all my posts up there look stupid
Yes you should... like real quick....before it gives you a problem
Sent you a PM. Thanks
:D big big thank you to glen at botany motor works spinning key fix on time and price will be servicing both our bmws from now on
also thanks to the members that gave me hints and advice thanks very much guys
