advantex 0 Report post Posted July 16, 2008 Very small drips coming from motor. Central, about midway between radiatior and motor. Feels oily but not oil. Any suggestions? Steering pump perhaps? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted July 16, 2008 (edited) Very small drips coming from motor. Central, about midway between radiatior and motor. Feels oily but not oil. Any suggestions? Steering pump perhaps? Waterpump or thermostat housing leaking....antifreeze feels oily...what colour is it ?? Edited July 16, 2008 by botanymotorworx Quote Share this post Link to post Share on other sites
advantex 0 Report post Posted July 16, 2008 Waterpump or thermostat housing leaking....antifreeze feels oily...what colour is it ??Was a bit hard to tell on the concrete - found the morning after. Very small leak perhaps a few mils per day at most. Only had ramps at time and it was a bit hard to determine where it might be coming from. Mate suggested it looked/felt a bit like fluid from steering pump - why I made that comment. It did leave a slight green/yellow shade on the outer edges of the drip spot if that is any help. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted July 16, 2008 Was a bit hard to tell on the concrete - found the morning after. Very small leak perhaps a few mils per day at most. Only had ramps at time and it was a bit hard to determine where it might be coming from. Mate suggested it looked/felt a bit like fluid from steering pump - why I made that comment. It did leave a slight green/yellow shade on the outer edges of the drip spot if that is any help. Sounds more like antifreeze (green) OE antifreeze is blue. Check it out properly ASAP Quote Share this post Link to post Share on other sites
advantex 0 Report post Posted July 16, 2008 Sounds more like antifreeze (green) OE antifreeze is blue. Check it out properly ASAPThanks, going in for full service next week. I will get them to check it all. Appreciated. Quote Share this post Link to post Share on other sites
