sjanett
Adjustable Springs
Hi guys,
I Found this on EBay. I was wondering if any of you have seen or used anything similar to these. And what your thoughts on them are.
Personally they seam too cheap to be anything decent...
Ebay Link
looks like they will make you higher rather than lower? :?
I had some similar but the james equivalent in the e36.
Sucked balls.
The actual adjustment on them sucked...could really only adjust 2-3cm before the coils coil-binded(hit eachother) because they were so crappy.
