central3
330 re-boot?
I had my 330 battery disconnected for a couple of weeks and now:
- the remote locking doesn't work (did before the battery was disconnected)
- the temp indication on the dash is fixed at +50.0 'C
- the fuel consumption readout is fixed at 6.6 km/l
- the other dash readouts that accompany the temp and fuel consumption are also fixed values
Anything I can do before I book her in at a specialist?
One for the road - how do you set the seat memory. I've tried a few button pushing combinations but no can do. Jap import so no manual.
Disconnect battery and charge overnight on an automatic battery charger. Then reconnect.
Should reset fine.
You may need to re-sync the keys - this you can do yourself.
Seat memory: Press Pos Number then M to memorise.
