User Name 19 Report post Posted August 4, 2008 Hi Guys I have a strange one i have put a shitfter on from cant remeber what car, think from e32 or e30 and the shift rod is to short to put it into 1st, 3rd, 5th do you guys reakon just putting a longer shiter rod should recitfy this Im currentyl running a e28 with getrag 260/6 (i know should have gone with e28 one but hay) it just missus the gears if i hold it in place so do you reakon putting a shifter rod with bout 4cm more on it should work yes you can hassle me bout not using right shifter lolz Quote Share this post Link to post Share on other sites
