buz413
E34 Turbo
No problem, $10,000 worth of turbo install.
i'd pay that, who in NZ would you trust to do the work?
10k think its bit less than that depends what sort of power you want ay,
bout 5k for turbo installation depending on what you want, then just ecu
common guys, this easy stuff and not that much modding most bmw's will handle around 600hp on stock internals
honestly talk to Topcat or Damo about there turbo probjects they done on m30 engines but im sure newer engines even easier
That might be overstating the case a little.
Most BMWs are probably ok to about 12psi or double the standard power output on stock internals, as long as the compression ratio isn't too high.
I would guess $10k and up if you are paying someone (ie drive in and drive out). You might get lucky (or cut corners) to keep the cost down. Allow a couple of grand (including labour) for contingencies.
all things are possible,
lets talk-bring check book.prefer not the rubber kind :P
