bumpstop325
E30 M30 springs
what sort of spring rates are ppl running in their E30 M30 powered machines?
Not loving the kings action in the front. Already broke a coil off one of my rear king springs so they have been replaced with some B+G springs. (only have rear set)
road or race, coilover or standard? I run 800 lb rear / 600 lb front currently but I think that will change soon now that I have gone to the e36 suspension setup.
Not that I run a M30, but probably similar weight.
550lbs/in coilovers up front.
Have run 350lbs/in also, feel great on the road but were a bit soft for the track.
If you don't want to go to coilovers, look for some around this rate.
Im not sure what i want at the moment. Still deciding on which way to go (coilover vs standard).
Im keen on Coilovers that are the right price. Keeping my ear to the ground for deals.
