beemwr 46 Report post Posted August 13, 2008 has any one experience of this? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted August 13, 2008 has any one experience of this? Its not straight forward, but it can be done. You need to research it properly and it cant really be done without spending quite alot of $$$$ Quote Share this post Link to post Share on other sites
beemwr 46 Report post Posted August 14, 2008 Apart from the pulleys etc which can be swapped.It is around fitting the loom to correct sensors and instrument issues. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted August 14, 2008 There is alot more to it than that. If you are asking these sorts of questions without researching it properly ... I would suggest that you dont even attempt to do it. It will cost money and you will need specialist help for it if you dont have the mechanical ability. Research first and do the maths....$$$ wise. A better option would to be buy what you actually want...at the end of the day...its still just a 318...but a little different and you'll have empty pockets. Quote Share this post Link to post Share on other sites
