_Alan_ 6 Report post Posted August 13, 2008 Hi all, I have recently installed front fog lights on the e30.. I have done a bit of research here and on some other forums about how to wire them in .. I've found out that the wiring loom is all there, all I need is a double switch in the cabin, a relay and fuse for under the hood.. and I should be sweet.. I noted from an earlier topic that the front fog relay is called K8 and it is usually black, and the fuse positions are no. 29 and 30. Firstly I'll need someone to correct me if the above is wrong.. and point me in the right direction.. I would also like to know what size fuse it is. Finally I will need the front fog relay and double switch so if anyone has these I'd be keen to buy. Thanks for the help Alan Quote Share this post Link to post Share on other sites
Cale 36 Report post Posted August 13, 2008 You're right, 29= Left fog light, 7.5 A (relay K8) 30= Right fog light, 7.5 A (relay K8) Quote Share this post Link to post Share on other sites
_Alan_ 6 Report post Posted August 13, 2008 You're right, 29= Left fog light, 7.5 A (relay K8) 30= Right fog light, 7.5 A (relay K8) Cheers man, now I just need the bits.. Quote Share this post Link to post Share on other sites
OLLIE 27 Report post Posted August 13, 2008 relay from any auto shop, proper bmw switch from ray at hellbm. actually just get both from ray. 0212hellbm Quote Share this post Link to post Share on other sites
_Alan_ 6 Report post Posted August 13, 2008 relay from any auto shop, proper bmw switch from ray at hellbm. actually just get both from ray. 0212hellbm Thanks Ollie. Quote Share this post Link to post Share on other sites
