User Name
Brakes+part numbers
hay guys
i recently got some brakes off hellbm (thanks ray) but the one thing that is confusing me is both brakes have the same part number and they dont match up to any of part numbers i can find,
the part number i can see off the caliperis 60 28 309 -im not doubting ray at allthat they are theright brakes just dont want to go and buy rotors then find out they dont fit,
the brakes are sposed to be off a 540i, still think its weird they have same part number that shouldnt matter at all right
cheersguys
hay guys
cheersguys
From what I remember, the 28 is the thickness & 309 is the diameter of the discs calipers can accomodate.
E34 540's are 300x28 aren't they? Sounds about right then.
Edited by E30-323ti
Thanks guys
yea i got the details but the do look aftermarket from like "AFT or something like that cant really read that but should be all good, once my other brakes arrive ill let you know, how well it stops lolz
Thanks guys
ATE maybe? They make the majority of brake components for BMW's (definitely in that era).
They should be the right items, 60 will be the piston size. ie mine say 57/25 and have 57mm bore and 25mm rotors. and glenns right with the 540i rotor size too.
