User Name 19 Report post Posted August 24, 2008 Hay Guys Adding to my last post i have worked out most of the wires and my engine bay and wiring harness def looks a bit nicer now i have to say my one issue is the main relay i think i have sused it out cause by what i get not all the wires are needed when converting cause some are grounds and just power of the old harness that goes to the ecu has anyone done this i would hate to get it together and try turn it over and blow something. does anyone one have any idea about testing before starting Cheers Quote Share this post Link to post Share on other sites
topcat 11 Report post Posted August 25, 2008 are you using a e32 loom or e28? Quote Share this post Link to post Share on other sites
User Name 19 Report post Posted August 25, 2008 Hay Marty Im using the e28 fuse box and the loom and ecu of the e32 which i have sussed out all the wires except for the ones that i need to connect to the main reley theres a iginition wire, power wire and a couple others just wanted to know do i put the corrosponding wires of the reley onto the e32 loom in the same way all the other wires do, im prob not making any sense let me know if im not Quote Share this post Link to post Share on other sites
