bmuu
stupid electrical problem
ive got a 325i e30 and whenever my headlights are on and i indicate to turn right my full beam turns on by itself and turns off once my indicator clicks off. doesnt do it when i signal left tho
anyone know how to remedy this??
Faulty dip switch - replace it to fix
Sounds like a bad earth or earth loop to me. Check the relays for the indicators and headlights.
Contradiction here - bad earth/ relays - two different circuits
Indicators dont use a relay
Probably dip switch fault - been there - done that!
oops, my bad. Unsure on BMW's as am new to them. Indicators do use a relay, a flasher relay.
Commonly known as flasher unit (& as I refer it to) rather than relay. That unit wont be affected by headlight operation to cause the stated problem
