User Name 19 Report post Posted September 21, 2008 Hi Guys quick run down. e28 shell with e32 m30b35 motor, have used e28 fuse box and e32 loom and ecu (getgrag 260/6) now my only problem after solving my fuel problem thanks to Glen (pipes round the wrong way), ive run into the problem that im not getting any tach readings or speedometer which linked into the tach. my problem being that i cant find the wire on the e28 main loom that connects to the e32 loom(or does it not) ive looked through all my wiring diagrams and electrical books and im stumped can some please help me OR im thinking that my speed sensor is in the gearbox that has wires coming from it???? cheers kym Quote Share this post Link to post Share on other sites
3series 0 Report post Posted September 21, 2008 (edited) Not that I have a clue what I'm on about when it comes to electrical systems but .... could it be a conflict between the 528 chip on the front of the instrument cluster and the new 735i engine management system. We swapped a few 320i clusters aroudn a few weeks back to see if we could fix a faulty cluster and sure enough, facelift did not like pre-facelift (varying ECU's). Edited September 21, 2008 by bmw3 Quote Share this post Link to post Share on other sites
User Name 19 Report post Posted September 22, 2008 Yea thort about that but the tach is controlled by the tachsensor and im geussing thats the wire i need to find and none of my wiring diagrams help cause i cant find ethier the one on the e28 or e32 loom they said for tach - black goes to black/brown but no luck can find it leading from the tach but then nowhere else and dont want o have to pull my interior out again Quote Share this post Link to post Share on other sites
