tire
quick question - rocker cover gasket
Do I need to use any sealant or product when installing a new rocker cover gasket on a m10b18 in an e30?
Or just dry?
Oh interesting question. I use a gasket sealer but have often wondered what if i didint. Never tested it because of time.
Just make sure all the old gasket is removed and both surfaces are clean and dry. Put the gasket on dry...no sealant required with a new gasket
