Jeddy
Replacing Fuel Tank & Fuel Pump
I had a bit of an accident today and managed to get something jammed up under my e30 which has damaged the fuel tank and presumably fuel pump as no fuel is making it to the engine.
My question, i'll be taking it somewhere(not sure yet) to get fixed by wanted to know what parts i'll most likely(trying to plan here) be needing to replace.
Fuel tank
Fuel pump
Cheers
firstly would check - is the pump getting power are the houses squashed at all
then fuel feed in the tank could be sealed by the accident
start from electrical - then to blockages etc
cause i have dented both my e28 fuel tanks and they seem fine
