sin-drome 0 Report post Posted October 12, 2008 hey guys I was just wondering if anyone could help me out with my little problem im having with my e46 well.. you know that little display where it shows your next oil service..then after that it shows the time, km per litre, how many k's you got in your tank..does anyone know what the temperature one means ? because mine is stuck on -40 C and its worrying me that something could be wrong. thanks for the help guys much appreciated Andrew, Quote Share this post Link to post Share on other sites
williams 0 Report post Posted October 12, 2008 there should be a temp sensor in the r/f front under the bumper,sounds like it is missing-this has a direct effect on the working of the a/c heater function. Quote Share this post Link to post Share on other sites
sin-drome 0 Report post Posted October 12, 2008 there should be a temp sensor in the r/f front under the bumper,sounds like it is missing-this has a direct effect on the working of the a/c heater function. hey im not to sure about this because before it was working fine its just now its stuck on - 40 C maybe the temp sensors broken ? what do you think ? thanks for the info Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted October 12, 2008 Its the outside ambient air temperature sensor. Its either disconnected or the sensor has failed. When this happens it always reads -40 Quote Share this post Link to post Share on other sites
