xtr041947 0 Report post Posted October 13, 2008 Hi All, anyone know the cost to do the sump gasket on the above, I have a AA warranty, anyone know if would\could be covered under warranty? Thanks in Advance.. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted October 13, 2008 Its approx $500. The gasket (gen) is $60 + oil + 4-5hrs labour +GST. You sure it is the sump gasket ??. The oil filter remote housings leak and so does the dipstick breather hose and rocker cover gaskets. If you havent already....get it checked properly. Autosure may or may not cover it. Depends what policy you have got AA warranty=Autosure. Ring them and check. Cheers Glenn Quote Share this post Link to post Share on other sites
