Andrew
E36 door stuck - n00b error
Hopefully someone has a quick fix for this.
I got another E36 today off G-Unit and since he has little kiddies it has the kiddie lock on.
I turned the lock in the right hand passenger door to disable it and then shut the door. I then tried to open it from the outside, no joy. No worries, I'll just pop it open from the inside and try again...but no it won't do that either.
The door handle feels SUPER stuck. I can't believe it is possible (if it is it is retarded) to get the kiddie lock to disable both door handles.
HELP!
Did I have the passenger kiddy lock on? Brook may have enabled it when she was using the car on Monday.
I used to enable the driver side one (where Ash sat), but thought I disabled that one today when I got the seat out of it.
I'm not sure how to sort it, is the owners manual any help?
Grant
