Gus
E30 Koni Prices
just for anyone interested..from stocks
FRONT STANDARD SUSPENSION 45mm HOUSING
862268SPORT Oil hydraulic twintube adjustable insert $ 296 +gst EACH
86411029SPORT Gas hydraulic twintube externaly adjustable insert $320 +gst EACH
FRONT SPORTS SUSPENSION 51mm HOUSING
862277SPORT Oil hydraulic twintube adjustable insert $ 296 +gst EACH
86411021SPORT Gas hydraulic twintube externaly adjustable insert $350 +gst EACH
REAR SUSPENSION
802522SPORT Oil hydraulic twintube adjustable insert $ 184 +gst EACH
261196SPORT Gas hydraulic twintube adjustable insert $ 181 +gst EACH
DOUBLE ADJUTABLE
$850 +gst EACH These would be a wet build up in our workshop . We would need your struts for this.
remember to inc GST.....a full set comes to around $1200..not bad
phat, konis are round :D
now you can do mine gus... :D always good to get them rebuilt every now and then.. oh wait konis will outlive your car B) ...
to be honest im pretty sure their rebound adjustable..check it out though
so in lamens terms r these adjustables??
wots the diff betmeen gas and hydro??
how mch for a full set up in 1990 316i?
gas use gas to dampen...oil use oil......gas are better
these are rebound adjustable (controls how fast the shock rebounds to full extension) the dual adjustables are both compression and rebound adjustable.
a 316 would have 45mm strut housings i imagine....use the prices up top
