Gus
Short Shift Prices
whilst im on the rampage...these are dealer prices
Z3 M lever - $126ish
Z4 3.0 lever - $136ish
both ex germany
Will either of those work with a 4 cyl E30? Those prices aren't too bad really, compared to what some place want for a specialist short shift kit
yeah should do...dont see why not....just bend the gear selector rod.....the UUC one is a "modified" bmw lever (ie is bent) with better bushings...very similar and more than double the price...not worth it in my opinion
the z3 1.9 is gay.....ive got pics of them all and its pretty much the same as the e30 one
tim the only thing i dont like about yours is that it artificially increases the length of the lever below the fulcrum....a proper lever IS longer
I've one from the BMW Z8 in my 323Ti Compact. As far as i know it's only suitable for this two cars. (It's 1,8 cm shorter)
By the way, i cut the original one a few cm's shorter and it works good as well.
I payed 64,- euro for the Z8 one at the local BMW dealer.
Gr,
Marcel
...or just buy a short shift lever...they not that expensive...not to mention a cleaner look....when your looking at your shift lever under your car <_< depends on how strong it would be....meh anyway....i cant weld
