Driftit 2215 Report post Posted October 30, 2008 Check out this beast on Ebay! http://rapidshare.com/files/158660762/Far....C-Unleashed.rar S50 3.0L Custom built Engine. This auction is for 1 S50 3.0L engine fully rebuilt using only BMW oem or better parts. The price is for base engine, transmission, M5 flywheel, M5 clutch, alternator, a/c pump, and starter. Rebuilt engine will include the following: ported and polished Head, Pollished and cc balanced combustion chambers, supertech high rev valve springs, Metrix Motorsport custom ground cam set, Metrix Motorsport Noiseless vanos unit, Titanium retainers, MLS head gasket, ARP head studs, Remanufactured S50 bottom With new rings, bearings, high volume oil pump, new timing chain, oil pump chain, and tensioner components. Metal water neck, low temp thermostat, front mount oil cooler, new sensors, OBDI wiring harness, 413 Motronic computer, performance software, euro M3 airflow meter, intake plumbing with silicone connectors, 28# fuel injectors, adjustable fuel pressure regulator, coil packs, new o2 sensor, Headers, and 255LPH fuel pump. Quote Share this post Link to post Share on other sites
Guest SamSpargo Report post Posted October 30, 2008 American parts, therefore it's a glorified M50. Quote Share this post Link to post Share on other sites
