caleb
Number of airbags in E46
How many airbags are there in an E46?
I always thought there are 6 airbags but found another 2 near the windscreen pillar ???
Should be 1 in the dash on passengers side.1 in steering wheel. 1 in each front door. 1 in each "A" pillar =6
Edited by *Glenn*
I found
1 in the dash on passengers side. 1 in steering wheel. 1 in each front door. 1 in each rear door. 1 in each "A" pillar =8
Could be your car is Jap import which generally is to higher spec than NZ market versions. My E39 has 10 air bags which is more than generally found in NZ new E39s
E39's had 8 up to 00 facelift when they gained two more- being rear side curtain
I'm pretty sure I've only counted 6 in my 2002 525i O.o
Steering wheel, LHS dash, all doors, A pillar each side then facelift added rear side curtain. Not sure on NZ new cars though
