sin-drome
E46 Gas pedal
Ok so heres my question guys and girls.
I own a 1999 318i and over the weekend i managed to drive my uncles 2003 318i just from japan i no the newer e46's have a newer engine as well as more HP but i found his gas pedal to be a lot more smoother/lighter if that makes any sense, currently in my car its a bit stiff and you really have to put your foot on the ground to get some power out of it. is this normal ? i no its just a 318i with 100 odd HP but should i get this checked out ? because there was a big difference to me.
this has been only the 2nd e46 ive driven so dont really know what to compare it to
thanks guys
Andrew :D
Edited by sin-drome
yours has a cable which becomes sticky-best to replace and ur uncles car is fly by wire
so its just a cable that needs to be replaced ?
