pureboiracer
anyone work with radiators and the like?
hey guys. my intercooler as a inlet pipe in the side at the top. the outlet pipe is in the side (on the other side of the intercooler) at the bottom.
i need one of the tanks flipped over so both pipes are at the top.
can anyone help???
Did you sort this out bro? Pretty sure the end tank can be chopped off and welded. Do you know anyone that can weld alloy? I have plenty of sources up here but im 3.5 hours away haha
Air con guys should be able to help. Alot of the bigger companies do their own alloy welding and make up pipes
