1rotty
e39 ignition barrel
Looks like I need a new one - keys sometimes dont want come out.It happens with all 3 keys so its not them.
Is this a dealer only purchase & do they require coding,(dealer quote 4 barrel $200 ex Germany) which I didnt think was too bad compared to a key at $400!!
Will be genuine only - that price doesn't sound too bad. Barrel itself wont need coding. Maybe a good locksmith can do something with your one??
Tip: if the mechanical key barrel is that worn, then you should also consider replacing the electrical part at the same time.
The E39 ignition switches wear and cause all sorts of electrical "gremlins" due to bad contacts.
So if the mechanical part is old and worn, the electrical part will be as well....
