Kaz
Uneven Height
Mine with no one in it, less than 20l gas (im so poor lol) and just everything pretty much standard is sitting around 85 at the CAB's. Subframe is about the same. Go measure yours at the CAB and let me know. With these springs in my 87 pre f/l 325i coupe and this 89 320i body both have been under 100mm. No rubber spring pad things either if that makes much of a difference.
What exactly is the CAB? Sorry if its a stupid question.
It was about 140-150mm if I messured correctly.
Guest FrantiC
I just went out and re-measured mine and I got 75mm this time... Heres a picture to show I'm not lying LOL.
why not just take the easy option cheap option and get the fronts re-set to suit eg 20ml or so
