plumbernz 0 Report post Posted November 14, 2008 (edited) my 97 3 is losing water about a liter every 5 - 10 ks but no leaks can be found no water on the ground or anywhere thanks for the one thing that it might be bmrmad Edited November 14, 2008 by cutit Quote Share this post Link to post Share on other sites
tire 10 Report post Posted November 14, 2008 probly going somewhere on the road Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted November 14, 2008 probly going somewhere on the road WOW Quote Share this post Link to post Share on other sites
QuickSilver 0 Report post Posted November 14, 2008 my 97 3 is losing water about a liter every 5 - 10 ks but no leaks can be found This is the most un-informed question I have ever read, you cant actually expect any serious answers here? Quote Share this post Link to post Share on other sites
Yamahoo 6 Report post Posted November 14, 2008 This is the most un-informed question I have ever read, you cant actually expect any serious answers here? It's not really a question, just a statement, like, "The wheels on the bus go round and round." The correct response is, "That's nice." Quote Share this post Link to post Share on other sites
QuickSilver 0 Report post Posted November 14, 2008 Yes, that makes even more sense haha. Hmm, Thats nice Quote Share this post Link to post Share on other sites
mynbmr 225 Report post Posted November 14, 2008 my 97 3 is losing water about a liter every 5 - 10 ks but no leaks can be found I had the same problem with my 525, and it ended up a cracked head Quote Share this post Link to post Share on other sites
Braeden320 0 Report post Posted November 14, 2008 (edited) Windscreen Washer Tank Leaking Post Details if you want a decent response Edited November 14, 2008 by braeden. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted November 14, 2008 Could be a heater or radiator hose.... you might have "cutit" Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted November 14, 2008 (edited) 97 E36 316 I M43 ?? I'm assuming... bad word Have a look at the back of the head. Theres a plastic water outlet there. It'll probably be leaking slightly and evaporating on the block or the exhaust. If you cant find the leak, pressure test it or get professional help before it all turns to custard on you. BTW..they also leak in the same area with the headgasket too, at the back, just below the same plastic fitting Edited November 14, 2008 by *Glenn* Quote Share this post Link to post Share on other sites
plumbernz 0 Report post Posted November 14, 2008 97 E36 316 I M43 ?? I'm assuming... bad word Have a look at the back of the head. Theres a plastic water outlet there. It'll probably be leaking slightly and evaporating on the block or the exhaust. If you cant find the leak, pressure test it or get professional help before it all turns to custard on you. BTW..they also leak in the same area with the headgasket too, at the back, just below the same plastic fitting thank you glenn if i cannot find it i will pop along to see you later today or monday Quote Share this post Link to post Share on other sites
Mike 1 Report post Posted November 14, 2008 my 97 3 is losing water about a liter every 5 - 10 ks but no leaks can be found no water on the ground or anywhere thanks for the one thing that it might be bmrmad Posts like this are why we have this thread: http://www.bimmersport.co.nz/forums/index....showtopic=15800 please read the stickies!!! Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted November 14, 2008 Looks like I was right...just got an email while having a lunch break. Will email later Cutit... I've got heaps to do here at the moment Quote Share this post Link to post Share on other sites
