User Name
E28/e32 M30b35 Oil Sump Screw Up - Plz Help
HI all
Ive being having massive issues with my car running right after the conversion, i got a oil pressure gauge and amazingly it was jumping all over the place so suspect my oil pump is having issue
so i decided to undo my oil sump and try take it off, and i got it stuck and couldnt put it back on,
does anyone have a quick way to get it or am i going to have to lift the engine up or drop the front cross members off to get at it
argh, just wish i had the cash to get it converted and worked over for my turbo otherwise i wouldnt waste\ well not waste my time fixing it and getting it going,
also the engine is hot even tho coolant is not so do figure oil issue, seen the car just stops and then wont start but turns over
..... and im not taking it to a mechanic cause most of them said they wont touch it or they look and go get a new car
but its my baby of 3 years with 1 engine swap,
any help would be appreciated
