CamB 48 Report post Posted November 25, 2008 I'm after the driver's exterior door handle (complete) and the exterior trim that goes around it for a late (as in '94/'95) E34. I don't know if they are different during the years. I need the ring that goes around the lock too, but the condition of the lock isn't important as I will use the existing one (the main housing of the handle has cracked). Number 1 - (which is cracked) from this one http://bmwfans.info/original/E34/Lim/525i-...41/ill-41_0724/ Number 1 (bung) and number 3 (missing, and the reason the bit above broke) from this one: http://bmwfans.info/original/E34/Lim/525i-...41/ill-41_0730/ Quote Share this post Link to post Share on other sites
JiB 2 Report post Posted November 25, 2008 Have a random assortment of E30 bits available if that reduces cost of E34 bits. Btw, whatcha using E34 bits for Cam? Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted November 25, 2008 Btw, whatcha using E34 bits for Cam? Father in law's car needs a little TLC Quote Share this post Link to post Share on other sites
HELLBM 1675 Report post Posted November 25, 2008 Can do.. Quote Share this post Link to post Share on other sites
