Docile 64 Report post Posted December 8, 2008 ok so i started my car this morning, warming it up .. then i went inside to get coffee.. when i sat down in the driver seat i saw the gear warning light was on i was like wtf !! i just drove the car last night and it was fine ... so i tried to put it on reverse, it engaged hard, which was unusual, then i put it in drive which also engaged hard... drove it out around for 200 meters and every time it shifts its like its struggling... and would only go up to 3rd -( 60 km) and wont go up to 4th gear nor 5th.. jacked up the car looked for leaks in the sump and it was spotless... had to take da 7 out to work any ideas?? trans is a a5s 310z Quote Share this post Link to post Share on other sites
*Glenn* 855 Report post Posted December 8, 2008 You will need to get it scanned first. Sounds like its in limp mode. It may or maynot be trans related. The scan will tell you. Quote Share this post Link to post Share on other sites
