JasonL
High output Alternator
Hi All,
Looking for an high output alternator or wher I could get one from in new zealand. Will be going into a E30. Needs to be around the 200amp mark.
Edited by DunzzersE30
Guest FrantiC
Unless you wanna try custom mount one, the best your gona find for direct fit in an e30 is 90amp.
why do you need 200 amps?
Running large audio.
2000w rms div by 0.80 alterntar power = 2500rms
2500w rms div by 14.4v (running power of battery) = 173.6amps
173.6amps I need to run @ 2000rms
Thats in subs alone.
:D Yeah they have them on ebay for like $500 was looking if I could get one in new zealand first before I buy one. I have already had to replace it once so far and im not helping it by buying more gear for it to run.
