oscar90 0 Report post Posted December 9, 2008 as above, so it doesnt come off as easy as me or dad thought... any tips? Cheers Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted December 9, 2008 32mm spanner (or 1.1/4"), L/H thread Give the spanner a "twack" with a hammer to break it loose DONT forget - its L/H thread Quote Share this post Link to post Share on other sites
Driftit 2215 Report post Posted December 9, 2008 Yes Lefty Tighty Right Loosey. Haha. I used a little penetrating oil too. Quote Share this post Link to post Share on other sites
Guest FrantiC Report post Posted December 9, 2008 Go to a local bike shop and pick up a 32mm headset wrench. They are about 2mm thick and fit easy in between the fan and water pump pulley. Most of the time putting the wrench over the bolt at 2 o'clock (facing towards the front of the car) and giving it a whack clockwise with a mallet will break it free. You may need to grab the V- belt across the alternator and where it goes down to teh crank again and tighten it to stop the waterpump pulley from moving. Quote Share this post Link to post Share on other sites
tibbs.james 1 Report post Posted December 13, 2008 Do you need to remove the Viscous part ? because you can just undo the 8 10mm bolts holding the plastic fan piece on if you don't need to remove the entire fan assembly. Quote Share this post Link to post Share on other sites
oscar90 0 Report post Posted December 13, 2008 nah removed the fan, one of the blades has snapped, as it has been lose/ moving around, thought there could be a cheats way but no such luck, all sorted now, thanks Quote Share this post Link to post Share on other sites
