ACS E46 0 Report post Posted December 10, 2008 Hi people, Not sure if any1 has had the same problem but if im cruising around 40kms my breaks/wheels start to squeek, almost like the brake pad indicators are workin, but i've replaced all rotors and pads on my car the other week. Also, the wheel bearings seem fine and have no play in them. What could that sound be? Any help would be fab. Cheers, Dan Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted December 10, 2008 You probably used non genuine parts.. we only use OEM for this reason. Check brake parts will do this. Quote Share this post Link to post Share on other sites
ACS E46 0 Report post Posted December 11, 2008 You probably used non genuine parts.. we only use OEM for this reason. Check brake parts will do this. Thanks for the reply Glen, but i have used OEM parts. Especially for the brakes cause they are good enough standard. Hmmm may have to send it into the shop then. Quote Share this post Link to post Share on other sites
euroitalian 63 Report post Posted December 11, 2008 Stone or other piece of crap lodged in caliper? Quote Share this post Link to post Share on other sites
ACS E46 0 Report post Posted December 11, 2008 Stone or other piece of crap lodged in caliper? I did pull the caliper off to see if it that was the case.. but no. Cheers anyway Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted December 11, 2008 I did pull the caliper off to see if it that was the case.. but no. Cheers anyway Have you bent the backing plate ?? Quote Share this post Link to post Share on other sites
ACS E46 0 Report post Posted December 13, 2008 Have you bent the backing plate ?? Hmmm i dint check that. Good point. Cheers man Quote Share this post Link to post Share on other sites
37 South 6 Report post Posted December 13, 2008 Not sure if any1 has had the same problem but if im cruising around 40kms my breaks/wheels start to squeek, Any help would be fab. Quote Share this post Link to post Share on other sites
37 South 6 Report post Posted December 13, 2008 Not sure if any1 has had the same problem but if im cruising around 40kms my breaks/wheels start to squeek, Any help would be fab.Sorry,disregard my last post.What i meant to say is, I had the same problem noise and it turned out to be a little stone that was lodged between the backing plat and the disc. Quote Share this post Link to post Share on other sites
