Driftit 2246 Report post Posted December 12, 2008 Hey guys I am looking for some good cleaning products that I can purchase in bulk. Has to be something that strips off old dirt and oil. E.g. Brake cleaner. But I am sick of buying the expensive brake cleaner cans. What can I get and where can I get it. I dont have a parts cleaning tray. If I had more space I would get one for sure. Quote Share this post Link to post Share on other sites
briancol 3 Report post Posted December 12, 2008 Try Resene's Tri-Sol, I get that in 5 litre containers which I think costs $25.25 + Gst. Quote Share this post Link to post Share on other sites
Driftit 2246 Report post Posted December 12, 2008 Ahh ok. Does it work in a similar way to brake cleaner? Good to strip off oil and greese? Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted December 13, 2008 Ahh ok. Does it work in a similar way to brake cleaner? Good to strip off oil and greese? I bought some brake cleaner stuff from BNT on special for about $6 a can. Seems just as effective as the expensive options. Quote Share this post Link to post Share on other sites
tibbs.james 1 Report post Posted December 13, 2008 (edited) Enviro Degreaser is the best product i have ever used. Many engine and machine shops use it instead of ACID dip. It comes in a 20L drum and if you put it in a bucket or a tank it can be used many times over and over again, even once its filthy black you can skim the gunk off the top and use it just as good as clean stuff. Works better than brake cleaner, totally non toxic, won't harm your skin . You generally only need to brush a little bit on leave for 5 minutes and hose off. Its quite expensive but one drum should last a whole year. Compare that to a $6 can .. and it works out a lot better. http://www.tergo.co.nz/Tech%20Data/HTML/En...20Degreaser.htm Edited December 13, 2008 by Jimmy Quote Share this post Link to post Share on other sites
