Gus
Cheap E30 Stuff updated
Hey Guys
I have a bunch of e30 stuff that I am selling over the next 3 weeks - I'm going to update this thread but here is the start of the list:
E30 318iS Turbo
M20 Sump
Front and Rear facelift brilliant rot bumpers (I might hold onto these)
Right hand side brilliant rot facelift coupe door
Mtech 1 wing (diamond schwartz, mint)
2 rear subframes
1 12" subwoofer
1 power steering rack
2 rear bilsteins (condition unknown)
M20 block / crank + associated gubbins, can't guarantee they are all there
front subframe
ABS control unit
Oil Cooler
Small case 4.45 diff
control arms
trailing arms
45 mm struts (these will be very cheap)
3 viscous fan clutches (condition unknown)
1 driveshaft (I think it's from a 318 auto)
1 M20 rocker cover
2 rear 1/4 windows e30 coupe, with shadowline
3 e30 brake master cylinders (some with boosters)
shadowline trim (right handside)
m20 fuel rail, + injectors
m20 cams
m20 afm
wing mirrors
1 front valance, reg - slight ding in centre however in good condition
4 14" basketweaves, 3 with really good bridgestone tyres
stuff added 28 Dec
325i Intake manifold
325i Throttle body
1 set 325i trailing arms
fan shroud m40
45 mm front suspension struts
2 BMW jacks
2 m20 bellhousing metal plates
+ 4 extra control arms (2 left 2 right)
1 drilled m20 airbox
2 AFM adaptors for pod filters
automatic pedal box
m20 oil pump
lots of misc hoses
2 m20 rocker shafts
lots of misc m20 brackets
mildly rusty diamond schwartz sunroof panel
3 radiator brackets
2 front sway bars (325i)
front 325i calipers
2 M20 AFMs
1 RHS headlight cluster (facelift)
m20 alternator
325i Facelift starter motor
2 e30 clutch master cylinders
1 CD stacker
1 good condition rear centre console
2 dashboard gauge cluster (1 325i, 1 318iS)
battery in boot cable
1 K&N pod filters
1 K&N panel filters
m40 water pump, metal impeller
1 325i water pump m20
seat rail to adapt bucket seat to e30 rails
e30 floor mats
m20 thermostat housing
2 facelift bumper shocks
Bel Sti Radar detector
I am unearthing more stuff - havent had time to put prices on stuff, but if you want them give it a go and ill prob say yes within reason, or just ask me and Ill price them
best way to get me is [email protected]
Edited by The Gus
bump - have added a bunch more stuff
get in touch!
yo, gustofogus!
lol i thought that was a cool name in the moment
you got a internal fuel pump you can flick for 30 plus postage ?
thanks
Guest FrantiC
What are the AFM's like? Any for a 325i, Need one for motronic 1.3 not sure if they are all the same or what but yeah.
yep, PMed
gus ,want to buy K&N panel filters,how much is it,plz pm me. cheers
Hi Gus,
are you able to post up images of the diamond swartz sunroof panel?
how bad is the rust?
cheers
Jon
hey guys
good to hear from you all. im just packing for hols, ill be back around the 5th - ill get in touch with you all then with prices etc
Merry New Year!
Gus
bump - seriously, some of this stuff will be super cheap - needs to go this week!
