Markq 0 Report post Posted January 3, 2009 HELP!! The socket for removing my spark plug wont come out!! It turns but wont grip enough to pull out. Any suggestions? Share this post Link to post Share on other sites
Markq 0 Report post Posted January 3, 2009 Any ideas?? Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 3, 2009 Is it the socket or the spark plug you are having problems with ? If its the socket, youve used the wrong size socket... you should use a magnetic 16mm for your spark plugs. To get the socket out, put a little supper glue on the tip of the extension, give it time to set and gently remove it while turning it slowly Share this post Link to post Share on other sites
Markq 0 Report post Posted January 3, 2009 Is it the socket or the spark plug you are having problems with ? If its the socket, youve used the wrong size socket... you should use a magnetic 16mm for your spark plugs. To get the socket out, put a little supper glue on the tip of the extension, give it time to set and gently remove it while turning it slowly Tis the socket. doesnt quite get onto spark plug. Slid down there easily and didnt push it down so is weird. Guess there is downward pressure anyways. Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 3, 2009 (edited) You must be using the wrong size socket... I take it you are trying to do this on your E39 535 ?? Edited January 3, 2009 by *Glenn* Share this post Link to post Share on other sites
Markq 0 Report post Posted January 3, 2009 FIXED. It was on a legnum. Share this post Link to post Share on other sites
sp8s 1 Report post Posted January 3, 2009 Shet like this is where I dig into my box and pull out the blue tack Put onto end of extension and push onto socket Put on screw driver and reach down to pick up dropped screw And so on Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 3, 2009 FIXED. It was on a legnum. Why the hell didn't you say so Share this post Link to post Share on other sites
Markq 0 Report post Posted January 3, 2009 Why the hell didn't you say so Problem the same no matter what the car...... Share this post Link to post Share on other sites
