Simo 0 Report post Posted January 3, 2009 Could anyone recommend an upgrade in the ECU to give a 325i a bit more weeze, I had a dyno done on the cherub, and it was a tad sad after 4500 rpm, and choked on its own smoke at 6500 rpm. Map ECU talked some numbers, but as the saying goes - pays to shop around thanks in advance Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 3, 2009 You need to talk to Gavin Bellars @ High Velocity. I dont have his number here at home, but I'm sure someone else might have it. Quote Share this post Link to post Share on other sites
Simo 0 Report post Posted January 3, 2009 You need to talk to Gavin Bellars @ High Velocity. I dont have his number here at home, but I'm sure someone else might have it. Thanks Glenn, will try to locate him Quote Share this post Link to post Share on other sites
briancol 3 Report post Posted January 3, 2009 Hi Velocity 16D Parity Place, Glenfield, Auckland [email protected] 09 442 4451 Quote Share this post Link to post Share on other sites
Simo 0 Report post Posted January 5, 2009 Hi Velocity 16D Parity Place, Glenfield, Auckland [email protected] 09 442 4451 Thanks for the address will follow this up Quote Share this post Link to post Share on other sites
