HELLBM 1626 Report post Posted January 5, 2009 (edited) `90 535 `93 530 `94 540 `97 328 `95,`97,`98 Compacts `97 323 `95 325 `95 318is x 2 `97 523 `97 528 `98 540 Lots of E30`s Edited February 8, 2009 by HELLBM Share this post Link to post Share on other sites
HELLBM 1626 Report post Posted January 28, 2009 `90 535 `93 530 `94 540 `97 328 `95,`97,`98 Compacts `07 323 `95 325 `95 318is x 2 `87 523 `97 528 `98 540 Lots of E30`s bump Share this post Link to post Share on other sites
Hi-Tek 3 Report post Posted January 28, 2009 Hi ray, not sure if I'll end up phoning you before you read this. I'm after a windscreen washer pump motor and horns for an E30 M3 (I'm assuming they'll be the same as an E30) Cheers, Ollie Share this post Link to post Share on other sites
HELLBM 1626 Report post Posted January 28, 2009 Hi ray, not sure if I'll end up phoning you before you read this. I'm after a windscreen washer pump motor and horns for an E30 M3 (I'm assuming they'll be the same as an E30) Cheers, Ollie Yes, can do. Regards Ray Share this post Link to post Share on other sites
