Andrew 30 Report post Posted January 18, 2009 Suit E30 http://www.trademe.co.nz/Browse/Listing.aspx?id=198462365 Again - from my racecar so usual wear and tear. Have old Dunlop Formula-R tyres on. Edit for pic: Quote Share this post Link to post Share on other sites
JiB 2 Report post Posted January 18, 2009 What would the offset be? Quote Share this post Link to post Share on other sites
Andrew 30 Report post Posted January 18, 2009 What would the offset be? No idea hah - they fitted my E30 sweet as. Quote Share this post Link to post Share on other sites
JiB 2 Report post Posted January 18, 2009 No idea hah - they fitted my E30 sweet as. Hmmm, what kinda brakes were you running? Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted January 18, 2009 (edited) Hmmm, what kinda brakes were you running? If you couldn't fit your new brakes behind the 4x114 ones you had (with the spacer), it is not gonna fit behind those. If anything it will be WORSE. (edit) oh - I just figured out you meant my car. I'd need spacers, for sure (25p 16x7s AC Schnitzers hit the struts), and don't want to go that way until I am forced to. Edited January 18, 2009 by CamB Quote Share this post Link to post Share on other sites
Andrew 30 Report post Posted January 18, 2009 Hmmm, what kinda brakes were you running? Wilwood dynalites with biggish discs. Were designed to fit under this wheel just. Quote Share this post Link to post Share on other sites
