Andrew
BBS RS 15" - $1 reserve
What would the offset be?
No idea hah - they fitted my E30 sweet as.
Hmmm, what kinda brakes were you running?
If you couldn't fit your new brakes behind the 4x114 ones you had (with the spacer), it is not gonna fit behind those. If anything it will be WORSE.
(edit) oh - I just figured out you meant my car. I'd need spacers, for sure (25p 16x7s AC Schnitzers hit the struts), and don't want to go that way until I am forced to.
Edited by CamB
Wilwood dynalites with biggish discs. Were designed to fit under this wheel just.
