grahamzhou 0 Report post Posted January 29, 2009 Hi all, i need some help here plz!! since last month, when i started my car, i felt my engine is very shaky. the revs was going up and down. so i pressed the acclerator softly to prevent the car stop running. once the car reached normal temperture, the problem seems gone. anyone knows what cause this problem please? Quote Share this post Link to post Share on other sites
silvermace 0 Report post Posted January 29, 2009 (edited) u need to get your car scanned. I just had a camshaft position sensor replaced and MAF done, could be either of those, similar symptoms. also, theres a pretty well known VANOS issue with the M52TU engine which is a rough start/idle for short trips, but you have a 330i which is M54 and I would have thought that it was resolved for these engines.. Edited January 29, 2009 by Silvermace Quote Share this post Link to post Share on other sites
Guest FrantiC Report post Posted January 29, 2009 Is teh car mis-firing? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 29, 2009 As Silvermace said....get it scanned first. It cant be solved in a forum....then deal with the problem... if your in Auckland I can scan it for you today or next week...just give me a call Quote Share this post Link to post Share on other sites
matt45 1 Report post Posted January 29, 2009 Hi, had Similar problem, turned out that one of the blades on the fan that runs directly off the engine (yes I am very technical…pffft) was broken, had the fan replaced and it ran fine from there on. But yes if its not that get it scanned could end up wrecking something if u leave it too long. Quote Share this post Link to post Share on other sites
