WarNox 1 Report post Posted February 12, 2009 Hey! Car: 93' e36 320i, 245km, manual So I get up today morning and the car won't start, doesn't turn over, nothing. Battery seems dead. 1. Try to jump start it and nothing, no turning over (so I figure its not the battery as it had the leads from another car going to it) 2. When I turn the key all I hear is clicking 3. Push starting starts the car 4. As soon as I turn the car off the battery goes dead STRAIGHT away 5. Water low in battery, fill it up and its currently charging So my question is. Is this a started motor problem combined with a dead battery? It can't be just the battery can it? As the car never turns over, just clicks. How do I check the solenoid? I've done some research but didn't come up with anything sufficient. Thanks for any help. Gregor Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted February 12, 2009 You may have too problems. I'd try a good battery first and check the charge rate. Should be charging around 14 volts. If it still wont start and the solenoid is clicking it will be a faulty starter motor Quote Share this post Link to post Share on other sites
WarNox 1 Report post Posted February 12, 2009 Ok, the battery has charged over night so will try it this afternoon and check the charge rate. I do think the started motor is gone though, how much do they cost approx? Is it a hard diy? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted February 12, 2009 Ok, the battery has charged over night so will try it this afternoon and check the charge rate. I do think the started motor is gone though, how much do they cost approx? Is it a hard diy? Try Ray @ HELLBM for a good second hand one. Not hard to fit Quote Share this post Link to post Share on other sites
WarNox 1 Report post Posted February 12, 2009 Do I have to take the manifold out to fit or can I do it from the underneath? I will give Ray a call later on today. Thanks Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted February 12, 2009 Do I have to take the manifold out to fit or can I do it from the underneath? I will give Ray a call later on today. Thanks Leave manifold on ...its a bit akward though if you havent got the right tools Quote Share this post Link to post Share on other sites
WarNox 1 Report post Posted February 12, 2009 Its ok, I got to change the rocker cover gasket anyway, so might as well do it all at once. Thanks for the help. Quote Share this post Link to post Share on other sites
