User Name
motronic dme 1.3 needed
Hi All
I have still had no luck with my car it starts runs fine when i wants and now and then i wont start again once its past of certian point of being on even tho the other week it was working fine so figure its new ECU testing time,
all i need is it running, - also would white smoke when i starts and oil water comming out exhast mean my head is leaking - compression is fine and havnt noticed water drop
My ECU part number is 12141748258 - its for a m30b35 either 535i or 735 DME 1.3 ecu, cause i figure itl cost the same to get it tested lolz
cheers
