jochen 4 Report post Posted February 17, 2009 Get it here: NavCoder v2.6.0 v2.6.0 16 February 2009 Added multi-lingual capability with many languages. Added checking for required LNG and OCX files on startup Added "Help - NavCoder Online" to Help menu Added "Help - Go to Resler I-Bus Interface Website" capability Added "Help - Contact Author" capability Added "Help - Check for Updates" capability Added "File - Export log file" capability. Exports as CSV file. Added Moneybookers.com as payment method Added Code BT to the Telephone dialog. You can code name, passkey, and emerg number To display nicely in Excel, use custom format of "00", and left-aligned for all cells. Fixed many small bugs and tidyed up error handling code a lot Fixed bug where failed headlight left & right were swapped Adjusted a lot of dialog layout to cater for multi-lingual text Added decoding of ibus command 0x31 "Buttons" for use with K1200 motorbike Built NavCoder website Quote Share this post Link to post Share on other sites
nordschleife 0 Report post Posted February 19, 2009 Thanks Jochen. I've downloaded and tried to get this running but when I attempt to register the regsvr32 msinet.ocx file I get an error saying LoadLibrary ("msinet.ocx") failed. Any ideas? I have a XP machine and the other three files registered OK. Quote Share this post Link to post Share on other sites
hybrid 1044 Report post Posted February 19, 2009 Read the bottom of the readme.text Quote Share this post Link to post Share on other sites
nordschleife 0 Report post Posted February 20, 2009 Read the bottom of the readme.text Sorry, I thought that was for Vista only, not XP. Working well now, thanks for the direction. Cheers Matt Quote Share this post Link to post Share on other sites
