grantdavis28
relay problems.
i was playing with the low beam relay in my e30 today trying to get my fog lights working.
when i plugged the relay back into k4 i noticed only one of the low bean head lamps work. i checked the fuses and there fine. also bmw couldnt find the relay i wanted.
so im stuck. could it be a bulb?
any help appreciated. also the product number for the lowbeam relay k4, and the product number for the foglight relay k8.
Thanks. Grant.
Could be a bulb. With respect, if you cant tell then probably best you get it to an auto sparky - prob a 5 min fix.
Relays in these cars are not standard termination (although terminal positioning is the same the configuration is different)
I have heaps of these relays if you need any
