Eagle
E30 325i Wheel alignment results
Car is lowered on H&R 40mm all round. Is the front toe correct?, cant seem to find out what the range is. Not to sure why the camber is .5 degree out, im sure pretty even last time i had one done 6 mths ago.
Front toe looks wrong - it isn't near the spec listed there.
Didn't think it it was right, what the range suppose to be? 0 toe >+0.5mm a side?.
Dont really know why the camber and toe for the right hand side are different, im sure it was pretty even last alignment. Maybe urethane bushings are failing.
